Appropriate time step size
Old   March 26, 2020, 04:25
Default Appropriate time step size
Ahmed
tahtawy is on a distinguished road
Hello
How to choose the appropriate timestep size and max iterations / time step in fluent when doing a transient analysis?
tahtawy is offline   Reply With Quote
Old   March 26, 2020, 04:57
Default Time-step
vinerm's Avatar
Vinerm
vinerm is on a distinguished road
Time-steps depends upon at least two things - the objective of the simulation and the case setup, i.e., is it multiphase, or dynamic mesh, or combustion, etc.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared on the Forum
vinerm is offline   Reply With Quote
Old   March 27, 2020, 00:33
Alexander
AlexanderZ will become famous soon enough
usually user want to use the biggest time step with least amount of iterations to get the result with certain accuracy level. Accuracy level may depends on what vinerm has mentioned
best regards
press LIKE if this message helped you
How to ask questions:
https://www.cfd-online.com/Forums/si...tml#post612025
AlexanderZ is offline   Reply With Quote
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 16, 2019 23:12
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 57 February 1, 2015 08:25
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 13:58
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 07:21
