Piston-fluid simulation
Old   March 26, 2020, 14:18
Default Piston-fluid simulation
RJE
Jedidi
RJE is on a distinguished road
hi guys,i want to simulate fluid (in fluent) that enter into a cylinder which have a piston linked to a spring that have a stiffness and a preload.
once the fluid enter in the inlet the piston will move to the right until the spring overcomes the force applied by the fluid.
i think that i shoud use dynamic mesh but i really need guiding.
help
RJE is offline   Reply With Quote
Old   March 27, 2020, 03:15
Default Piston
vinerm's Avatar
Vinerm
vinerm is on a distinguished road
Fluent has a 1DOF model based on 6DOF. It has an inbuilt spring model as well. You can make use of it.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared on the Forum
vinerm is offline   Reply With Quote
Old   March 27, 2020, 07:20
RJE
Jedidi
u mean 6dof option using dynamic mesh ?
Old   March 27, 2020, 07:45
Default 6dof
vinerm's Avatar
Vinerm
Yes, that's what I meant. Within 6DOF, it has a 1DOF option which is meant for scenarios similar to yours.
Regards,
Vinerm
Old   March 31, 2020, 11:22
Default fluid-displacement
RJE
Jedidi
hi, i'm entering a fluid in a cylinder with profile of pressure p(t) and i want to see how fluid in moving in the cylinder due to the force of the pressure.
any help ?
Old   March 31, 2020, 11:28
Default 1dof
vinerm's Avatar
Vinerm
That's exactly what 1DOF (or 6DOF) simulation does. Look for a tutorial on this; most likely it is available on ansyshelp.ansys.com
Regards,
Vinerm
Old   March 31, 2020, 16:24
RJE
Jedidi
i 've seen tutorials w they are all defining new interfaces.
i don't know why ?
Old   April 1, 2020, 03:15
Default Interfaces
vinerm's Avatar
Vinerm
There is a reason for the interfaces, however, interface requires an external domain, which you don't have. If the wall of the cylinder is an interface, piston can slide easily and no mesh deformation is required, however, this requires a domain outside the piston wall. You may create a thin solid layer representing cylinder to use that methodology. Better option is to define the wall of the cylinder as deforming. The reason it is deforming is because its size is changing as the piston moves up and down. The meshing in the fluid region can be controlled either via layering, if mesh is made of prisms (quad or tri), or via remeshing, if mesh is made up of tet cells.
Regards,
Vinerm
Old   April 1, 2020, 11:34
RJE
Jedidi
As a beginnig i want to model the problem in 2D as u can see in the attached photo . in the orange zone, between the piston and the fluid, there is a contact? what kind of boundary condition should i make there ?
File Type: jpg 91624718_1105106949833152_6844056078670364672_n.jpg (43.5 KB, 9 views)
Old   April 1, 2020, 12:20
Default Wall
vinerm's Avatar
Vinerm
Piston's crown is no-slip wall. Model it as axisymmetric. 2D planar implies a rectangular piston.
Regards,
Vinerm
Old   April 1, 2020, 17:04
RJE
Jedidi
Hi again,
For the inlet which is a wall, i want to enter a pressure profile , i read it then when i want see th motion, it seem like "Warning: Can't identify any field of profile pressProfile.
No motion specified."
i wonder if there a way to enter a pression via that wall
that inlet wall in used in the dynamic mesh and will be the reason of the defomation in the fluid
Old   April 3, 2020, 10:54
RJE
Jedidi
i enter at first inlet as pressure inlet w i have the same problem, fluent can't read it as i guess.i'm stuck in this pb for a good while.
if u have any idea that could help me i'll appreciate that.
Old   April 6, 2020, 05:58
Default Inlet as wall
  #13
vinerm's Avatar
Vinerm
Inlet should be inlet and not wall. No fluid can enter through a wall. If, for any specific reason, you want to model inlet as wall, then you have to provide some source term to increase either the volume, which can be due to increase in the mass or the pressure.
Regards,
Vinerm
Old   April 6, 2020, 07:40
Default pressure-inlet
  #14
RJE
Jedidi
that's mean that we can't apply pressure in a wall.
i apply pressure in the inlet as well and i putted fluid as deforming in the dynamic mesh but also there is no movement in the fluid
and i get this warning ; Can't identify any field of profile pressProfile.
Old   April 6, 2020, 07:46
Default Boundary Condition
  #15
vinerm's Avatar
Vinerm
Even in real life, no pressure can be applied by a pressure until and unless the wall moves, e.g., the walls of a container or a room. The only way a walls can cause such a thing is if it is porous or if there is some reaction occurring that increases the mass or the temperature, which in turn increases the pressure.
No cell zone should be defined as deforming zone. It should only be boundaries that need to be defined as deforming. Cell zones could have a motion defined though. However, for your case, it has to be done via one-DOF. I hope there are tutorials available online for this.
Regards,
Vinerm
Old   April 6, 2020, 07:59
RJE
Jedidi
what do u mean by 'It should only be boundaries that need to be defined as deforming.' ?
1DOf can be applied only for rigid body as i know w not a deforming fluid
Old   April 6, 2020, 08:14
Default Deforming Zones
  #17
vinerm's Avatar
Vinerm
In Fluent, you need to define the boundaries that deform or move. For the deforming options, only boundaries should be selected. E.g., in your case, the size of the fluid region will increase, in other words, it will deform. But you should not define this cell zone as deforming. However, the sides of the cylinder must be defined as deforming.
Regards,
Vinerm
Old   April 6, 2020, 08:31
RJE
Jedidi
ah ! ok i get it i 'll try that. thanks for the explanation
Old   April 6, 2020, 11:28
RJE
Jedidi
hey again,
if i i have understood well,
this is the fluid (oil)
Old   April 6, 2020, 11:32
Default Tutorial
  #20
vinerm's Avatar
Vinerm
I suppose the following tutorial should be able to help you
https://www.youtube.com/watch?v=aO1a4-Zm7Ag
Regards,
Vinerm
AVL FIRE ESE Diesel piston simulation initial condition rdrd4u AVL FIRE 1 July 15, 2015 01:53
Simple piston movement simulation ReVl27 FLUENT 1 February 20, 2015 08:28
variable density in single fluid simulation not running with total energy viking CFX 2 September 18, 2012 20:19
Expert parameter to stop the fluid flow simulation KK CFX 1 February 25, 2008 16:29
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
