March 29, 2020, 10:40 |
Viscosity UDF
Lee Jo
Rep Power: 6 |
Hi..
I'm modelling a trans critical combustion of CH4-LOX.. I was looking for any UDF codes which can be used for cryogenic combustion...the default kinetic theories doesn't seem to work... Can anyone provide UDF code for mixture viscosity.. |
March 30, 2020, 04:07 |
Mixture Viscosity
It appears that the requirement is not just the UDF but some physical model that is applicable for your case. As far as UDF is concerned, it would be easy to write provided you have a model for viscosity. For a model, you have to do some study; look through the literature.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
Viscosity UDF works when interpreted, Doesn't when compiled? | bloodflow | Fluent UDF and Scheme Programming | 4 | April 11, 2019 09:06 |
subgrid turbulent viscosity for UDF in LES | David TAIEB | FLUENT | 0 | April 2, 2007 08:27 |
Help !! UDF for second phase viscosity. | yong | FLUENT | 2 | January 24, 2007 11:11 |
UDF of Turbulent viscosity | justin | FLUENT | 0 | November 24, 2006 06:36 |
Problems with changing turbulent viscosity by UDF | sarah_ron | FLUENT | 0 | February 14, 2005 00:31 |
