Drawing multiple reference frames (tutorial)
2 Attachment(s)
I got some problems with drawing the geometry like in the tutorial 'using multiple reference frames.'
Attachment 76028 Could anyone help me with some advice on which one could be correct to draw the geometry for MRF? and what are the non-overlapping interfaces? Attachment 76029 |
Overlapping Domain
Overlapping domains are allowed only with overset meshes, otherwise, you cannot use overlapping domains. As far as interfaces are concerned, ideally they should have 100% overlap. This is usually not possible because mesh is discrete. Therefore, only the first drawing is correct. The problem with the last one is that you will end up with single cell zone; i.e., you can either set whole of it stationary or whole of it rotation, leading to Single Reference Frame.
2 Attachment(s)
Thanks. I followed your comment, but I can not define two interfaces (red line and blue line), error message saying overlapping named selections should be resolved. 'The mesh file exporter does not support overlapping geometry in named selections. Please resolve the issue and try again.' Following messages classified the second interface (blue line) to another group in mesh, which caused the interface not to appear and mesh interface in fluent not to be set with red line. Could you tell me what's wrong with this? Attachment 76045 Attachment 76049 |
Model for MRF
You have a single body in your CAD model. For using MRF, each body should be separate, as mentioned in my previous post.
1 Attachment(s)
Units
What is implied by Units? Do you mean physical units or geometric units?
What's important is that the meshing should see three different bodies but if you open Meshing you will see that there is only one body. |
1 Attachment(s)
I drew the geometry as in my figure with separate ones, which you recommended. Attachment 76053 But in Meshing, it still showed just one body. What do I have to do resolve this issue? |
Names
I don't know where you generated the CAD but if it is in DM, then just use Named Selections for individual bodies. That will maintain those as separate bodies. Other option is to ensure that all bodies are part of same part, however, keeping those in same part is helpful in maintaining good quality mesh and you won't have to use any interfaces.
Hi vinerm
I want to use MRF approach with overset grid. Does it possible. I have a rectengular prism domain inside a İt a spherical domain that contains the solid body. I meshed the domains seperately and combine them to create an overset grid. Then I want to apply rotation inside the spherical domain. When I run the simulation I got forces 2 to 3 times of the experimental results. In your opinion what is the possible cause of the error. Regards Quote:
