Fluent kw-wj-bsl-earsm model
I found that fluent has more turbulence models, which are not displayed on the interface, such as ‘kwi -easm’, ‘ke-easm’, etc. I can use (allow-easm-model) to make the first two available in the interface.
https://www.cfd-online.com/Forums/fl...softwares.html Now I want to use the "kww -wj-bsl-earsm" model. I have tried some similar commands, but they all failed. Can anyone tell me how to choose this model? |
Turbulence Model
Though you can use scheme commands but allow function is not defined for each model. So, you can either use the following command
(rpsetvar 'kw-wj-bsl-earsm-on? #t) Or just enable beta feature. Enabling beta feature has an advantage because then user is aware that the model is in beta version and not validated as yet. |
2 Attachment(s)
Command
You are mixing two things - TUI and Scheme. Scheme commands are supposed to be used without entering any TUI command. So, come out of TUI commands, i.e., press q until you are in home menu. Or simply enable beta features.
The TUI command to enable beta features access is:
/define/beta-feature-access yes ok Code:
/define/models/viscous/kw-wj-bsl-earsm? yes |
