Error in Chemkin and thermo file during creation of flamelet |
September 12, 2019, 07:03 |
Shyamal Bhunia
Rep Power: 11 |
Hi all,
I am trying to create a flamelet using chemkin.inp and thermo.db. I will use the subsequently generated PDF for non-premixed simulation of turbulent ethylene flame. While importing the chemkin and thermo files it shows an error 'invalid unit data, h, at line no XXX'. Please find attached the snap for reference. Thank you. |
April 16, 2020, 13:25 |
Samuel
Hello, did you find a solution for this? I'm having the same problem
April 16, 2020, 13:31 |
Error
The error in his case is very clear; there is data or reactions for some specie that is missing from the list. Just add the specie in the list or remove its data if the specie is not important.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
April 16, 2020, 13:49 |
Samuel
Well, I am only getting the message: "Invalid UNIT data, h, at line no. 461". I have checked it and H is in the species list so I don't know what's happening.
I have also checked the file chem.out that fluent generates when trying to import a chemkin model and it says that there are no errors in input files. |
April 16, 2020, 14:40 |
Chemkin File
Could you attach the file here?
chemkin, flamelet |
TUI command to import chemkin file | Aero_Tn | FLUENT | 3 | May 13, 2019 06:00 |
thermophysicalProperties for molWeight and Chemkin file. | massive_turbulence | OpenFOAM Running, Solving & CFD | 0 | January 3, 2019 01:03 |
chemkin thermo data | Weiqiang Liu | FLUENT | 4 | September 19, 2018 11:23 |
convert chemkin file ino format | nimasam | OpenFOAM Pre-Processing | 4 | December 29, 2016 15:01 |
combustion thermo file | dram | Main CFD Forum | 1 | September 9, 2009 08:37 |
