Simulation of NACA 2412 results from Theory of wing sections
As a part of our project we are trying to simulate the results from Theory of wing sections by Ira Abott for NACA 2412. Our Cl values are matching the graph values for 5.7e6 reynolds number with standard surface roughness, but we are not able to do the same for smooth wall. Even though the default settings of ansys fluent are that for a smooth wall, we are only able to match the standard roughness values. We have tried improving the mesh several times to no avail.
Any insights into why this is happening will be appreciated. Model- K omega sst Reynolds number- 5.7e6 |
Coefficients
Are you getting lower or higher than expected value?
Coefficients
Thank you for your inputs
1 Attachment(s)
But the settings in Ansys fluent correspond to a smooth wall (as roughness height is zero). How is it possible that the values of simulation of smooth wall match with value of standard roughness condition? Are these simulations acceptable? Kindly find the attachment image |
Looking into the data suggest standard roughness has LE trip and probably smooth wall doesn't have trip. If this is true, try using transition model with laminar flow till some percent of chord. |
Roughness
The effect of roughness on the flow is significant only if the roughness is larger than the viscous sublayer. Any roughness smaller than that implies smooth wall. So, you have to look at the thickness of boundary layer in your case and the roughness value. If the case is more or less smooth, then the results should match. If roughness is much more than viscous sublayer, then result match could also be due to the reason that the boundary layer is very thin and, hence, viscosity does not play much role and whole of the stress is due to turbulence.
