QMOM Boundary Values
Old   October 27, 2014, 09:37
Default QMOM Boundary Values
Laurens Tijsseling
l.tijsseling is on a distinguished road
When using the QMOM method to solve the PBE's Fluent requires boundary values for each moment (0 to 5). After a thorough literature research I haven't been able to find how to compute these boundary values.
Anyone with a solution?
l.tijsseling is offline   Reply With Quote
Old   September 23, 2015, 21:50
Meng Liu
sola86 is on a distinguished road
Now,do you know how to set boundary values?
sola86 is offline   Reply With Quote
Old   October 9, 2015, 06:23
Laurens Tijsseling
Yes I did! Have you found them yet or do you need help?
Old   October 9, 2015, 07:13
Meng Liu
Yes,I need! What's the principle to set the BC values of moments. Did your simulation results coincide with your expectations? Did you ever try DQMOM method?
Old   October 9, 2015, 07:20
Meng Liu
Old   October 9, 2015, 08:41
Laurens Tijsseling
They did eventually agree with the expected results. I have not used the DQMOM, as I was only working with two phases.
You know moment-0 is the number of bubbles, moment-1 the total length, moment-2 the total area and moment-3 the total volume. You need these values in #/m3. The parameter you decide is the diameter of the bubble.
Please note that moment-3 has the same value regardless of the bubble diameter.
As I only specified boundary conditions at the inlet, moment-0 was 1/volume one bubble and the others can be deduced from there.
I achieved most succes using the Luo coalescence and break up kernel.
Old   October 9, 2015, 08:58
Meng Liu
Sorry, I can't understand what you mean by the following. Can you explain it in detail?
“You need these values in #/m3. The parameter you decide is the diameter of the bubble.
As I only specified boundary conditions at the inlet, moment-0 was 1/volume one bubble and the others can be deduced from there”
Old   October 9, 2015, 09:13
Laurens Tijsseling
I'll send you a PM for contact details.
Old   October 9, 2015, 21:02
Meng Liu
OK, thank you. Or you can send me an email. My email is nel86@qq.com.
Old   December 5, 2015, 01:07
wubin
Athena is on a distinguished road
Hellow, have you meet the trouble about adding correction term into sorce term? I don't know how to add it reasonablely.
Athena is offline   Reply With Quote
Old   May 5, 2016, 00:00
winkungzxl is on a distinguished road
Up this topic
Really need the answer tho
winkungzxl is offline   Reply With Quote
Old   November 14, 2017, 01:57
Default QMOM boundary moment values
  #12
Chuchu Liang
Linda Liang is on a distinguished road
You mean only the moment-0(1/one bubble volume) would be specified at the inlet when the DQMOM is used? Is the diameter of the bubble an averaged one? If the diameter of bubbles is a size distribution, how to set the boundary values? Thanks in advance
Linda Liang is offline   Reply With Quote
Old   May 13, 2019, 00:40
Dhiraj Lote
dhiraj.lote@gmail.com is on a distinguished road
Can you please help me for reconstruction of bubble size distribution from QMOM
dhiraj.lote@gmail.com is offline   Reply With Quote
Old   May 27, 2020, 04:05
Smile
  #14
Wang Mengdie
Maud Wong is on a distinguished road
hello, I have questions about setting boundary values at the inlet in DQMOM, I don't konw how to set the moment4's value, can you give me a hand? Thank you in advance! my email:1025028835@qq.com
Maud Wong is offline   Reply With Quote
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
error when calculating values at boundary using refCast prabhu OpenFOAM 7 March 12, 2018 08:31
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
inlet velocity boundary condition murali CFX 5 August 3, 2012 08:56
CFX13 Post Periodic interface EtaEta CFX 7 December 8, 2011 17:15
