Negative reaction rate
Old   April 24, 2020, 05:41
Default Negative reaction rate
lili
lilistar-8216 is on a distinguished road
Hi, everyone.
I'm trying to check species consumption and generation using net reaction rate of species and kinetic reaction rate of reactions from Fluent data. But some values of these parameters were negative. I think that the reaction rate of them would be negative when the species are consumed and kinetic reaction rate would be negative when the reactions are reverse. But I'm not sure if it is right or not. If somebody know why these values are negative, let me know.
lilistar-8216 is offline   Reply With Quote
Old   April 24, 2020, 09:24
Default Negative Reaction Rates
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Yes, your understanding is correct. Reaction rate can go negative if look at the expression 7.1-8 for total reaction rate
https://www.afs.enea.it/project/nept...th/node129.htm
However, to confirm, you can disable backward reaction and check if you still observe any negative rate.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
fluent, reaction rate
Error in New Surface reaction model (Having multiple reactions) surajkvs OpenFOAM Programming & Development 2 May 23, 2023 22:21
mass fraction instead molar concentration in reaction rate iiigoriii OpenFOAM Programming & Development 0 November 16, 2018 11:03
Reaction rate under multi phases kongl1986 Fluent UDF and Scheme Programming 3 September 7, 2012 09:43
methane steam reforming reaction rate... yerem3 FLUENT 0 August 30, 2010 10:43
Plotting Surface Reaction Rate Ryan FLUENT 0 February 12, 2003 15:47
