TUI refractive-band
Old   April 22, 2020, 11:34
Question TUI refractive-band
TonyP is on a distinguished road
Hello everyone,
I am struggling with the discrete ordinate model in TUI. After succesfully loading a case and turning On the discrete ordinate model with 2 bands, I fail at defining a material refrative index. Here is the relevant part:
/define/materials/change-create/glass/ glass glass is a solid
change Density? [no] no
change Cp (Specific Heat)? [no] no
change Thermal Conductivity? [no] no
change Absorption Coefficient? [no] yes
methods: (constant piecewise-linear piecewise-polynomial polynomial gray-band user-defined-gray-band user-defined)
new method [constant] gray-band
band1 (1/m) [0] 0.1
band2 (1/m) [0] 0.8
change Scattering Coefficient? [no] yes
band1 (1/m) [0] 0.
band2 (1/m) [0] 0.
change Scattering Phase Function? [no] no
change Refractive Index? [no] yes
Refractive Index
methods: (constant refractive-band)
new method [constant] refractive-band no data required.
As you can see I can define the absorption and scattering coefficients but for some reason not the refractive index.
I am using Ansys Fluent 17.1 in 3D.
Thanks in advance,
Tony
TonyP is offline   Reply With Quote
Old   April 26, 2020, 16:59
Default Refractive Index
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Try list-properties for glass and see what it shows for refractive-index.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   April 27, 2020, 04:20
Default RE: Refractive Index
Thank you for your interest in the question vinerm.
Before the command detailed in the first post (/define/materials/change-create/glass/ glass), I get
property name                        units       method      value(s)
Absorption Coefficient               1/m         constant    0
Scattering Coefficient               1/m         constant    0
Scattering Phase Function                        isotropic   #f
Refractive Index                                 constant    1
And after the command, it is changed to
Absorption Coefficient               1/m         gray-band   (0.1 0.8)
Scattering Coefficient               1/m         gray-band   (0 0)
Refractive Index                                 refractive-band  #f
Old   April 28, 2020, 11:42
Default Bug
vinerm's Avatar
Vinerm
Could be a bug in that version. It is showing unassigned (#f). One way out is to write a user-define material database after defining the coefficients for the bands using GUI. The user-defined database is written in Scheme language and you can open it in any text editor. Look for the values that you have defined. Now, anytime you want to change the values, delete the existing material, change the values in the Scheme file, and reload the Scheme File via User-Defined Database. You won't have to modify any of the properties using the commands that you are using. Modify all together within the Scheme file and just read it.
Regards,
Vinerm
Old   April 28, 2020, 12:48
Default RE: Bug
All right, thanks for the tip
discrete ordinate model, non-gray, refractive index, tui
Is it possible to give each band different emissivity in Fluent Radiation? jswony11 FLUENT 3 July 25, 2023 05:03
Variation in refractive index sanchita.abrol CFX 5 February 2, 2021 15:20
TUI 'if' statement depending on Total Wallclock time? bloodflow FLUENT 1 August 25, 2019 22:21
TUI Commands from GUI? Carlos FLUENT 6 May 22, 2013 18:05
Define animate using TUI Zurlugh FLUENT 1 July 24, 2008 08:55
