Fluent Mixing: Stationary Body not Affected by Rotating Body?
Old   May 4, 2020, 11:52
Default Fluent Mixing: Stationary Body not Affected by Rotating Body?
Huyun Chen
chenhuyun is on a distinguished road
Hi all,
I am trying to simulate mixing using a mixing tank with an offset impeller. I would like to visualize how velocity vectors are evolving over the duration of the mixing time.
The total volume in the mixing tank is defined as the stationary zone, while a small cylindrical volume that encompasses the impeller is defined as the rotating zone.
I have set the rotating cell zone conditions to be rotating at an absolute rpm, and the stationary cell zone to be stationary.
However, when I run the calculations, the contours of velocity magnitude shows that only the rotating zone has any fluid velocity, and the stationary zone fluid has zero velocity (see attached picture).
How can I make it so that the fluid motion of the stationary zone is affected by the rotation of the rotating zone?
Thanks
chenhuyun is offline   Reply With Quote
Old   May 5, 2020, 06:51
Default Connection
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
Rotating body and the stationary region should have a communication. In Fluent, if you are using Frame motion, then this communication can be via interior boundary or interface. If you use mesh motion, then it must be via interface. It appears that you are using Frame motion and not Mesh motion. Just ensure that two zones are connected via interior, i.e., the boundaries where both touch each other are not walls but interiors. In case you observe any wall-wall-shadow pairs, then change those to interior and then run the case.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Need help with FLUENT Mixing Plane Tutorial pchoopanya FLUENT 0 November 24, 2019 01:13
How to simulate a cylinder rotating in stationary fluid in ANSYS FLUENT? Nitesh_CMG_GUY FLUENT 0 October 18, 2019 08:44
Opening frame type (rotating, stationary)? urosgrivc CFX 0 July 3, 2017 05:24
Rotating or stationary domain in pump/turbine cavity Christian Høy CFX 3 March 17, 2017 06:03
horizontal axis wind turbine- Issue in interface b/w stationary and rotating domain. srijithbbk CFX 5 February 22, 2016 04:20
