How to View Contour Scene while Solving
Old   May 4, 2020, 15:35
Default How to View Contour Scene while Solving
Chris
Chris2337 is on a distinguished road
Hello Everyone,
I'm coming from using Star-CCM+ so this may be a simple question for Fluent folk, but when locally running Fluent is there a way to minimize the residual plot while solving to observe other plots and/or scenes in real time?
Thanks,
Chris
Chris2337 is offline   Reply With Quote
Old   May 5, 2020, 07:19
Default Contours and Other Fields
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
You do not need to minimize residuals to view other fields, however, you need to set those up before starting a simulation. In Fluent, don't know how it is in CCM, you can stop at any instant and view the results and start from that point again. Not a good way but handy at times. You can set up Fluent animation where Fluent keeps on updating contours, or vectors, or xy-plots with iterations or time-step in their own windows; you can use multiple. Or there is an option called Fluent As A Server wherein you can post-process or monitor a case while it is running in batch mode.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Maximum number of iterations exceeded chtmultiregionsimpleFoam Moncef OpenFOAM Running, Solving & CFD 28 July 13, 2020 14:26
HeatSource BC to the whole region in chtMultiRegionHeater xsa OpenFOAM Running, Solving & CFD 3 November 7, 2016 05:07
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 02:50
Cannot run the code properly: very large time step continuity error crst15 OpenFOAM Running, Solving & CFD 9 December 14, 2014 18:17
pisoFoam with k-epsilon turb blows up - Some questions Heroic OpenFOAM Running, Solving & CFD 26 December 17, 2012 03:34
