[Sponsors] | |||||
Rep Power: 14 ![]() |
Hello,everybody,i want to simulate the process of frost formation at the cooling plate.i use the Euler model,adding a mass transfer source in the two phase interaction.In the Euler multiphase flow model ,the primary phase being the gas (humid air) containing dry air and water vapor and the secondary phase being the solid (ice), and one species transport equation was used to consider the masstransfer between vapour and ice. the following is the udf of define_mass_transfer:
#include "udf.h" #include "sg_mphase.h" DEFINE_MASS_TRANSFER(liq_gas_source,cell,thread,fr om_phase_index,from_species_index,to_phase_index,t o_species_index) { real hr; real Wvs; //vapour mass fraction in saturated condition// real Wv; //vapour mass franction in wet air// real m_lg_m; real Pvs; real Pv; real Td; Thread *tf = THREAD_SUB_THREAD(thread,from_phase_index); Thread *ice = THREAD_SUB_THREAD(thread,to_phase_index); if(C_T(cell,tf)<=273.15 && C_T(cell,tf)>173.15) { Pvs=exp(-5674.5359/C_T(cell,tf) +6.3925247 -9.677843*pow(10,-3)*C_T(cell,tf)+6.22157*pow(10,-7)*C_T(cell,tf)*C_T(cell,tf) +2.0747825*pow(10,-9)*C_T(cell,tf)*C_T(cell,tf)*C_T(cell,tf) +9.484024*pow(10,-13)*C_T(cell,tf)*C_T(cell,tf)*C_T(cell,tf)*C_T(cel l,tf)+ 4.1635019*log(C_T(cell,tf))); } else if (C_T(cell,tf)<=473.15 && C_T(cell,tf)>273.15) { Pvs=exp(-5.8002206*pow(10,3)/C_T(cell,tf) +1.3914993-4.8640239*pow(10,-2)*C_T(cell,tf) -4.1764768*pow(10,-5)*C_T(cell,tf)*C_T(cell,tf) -1.4452093*pow(10,-8)*C_T(cell,tf)*C_T(cell,tf)*C_T(cell,tf)+6.545967 3*log(C_T(cell,tf))); } hr=0.622*Pvs/(101325-Pvs); Wvs=hr/(1+hr); Wv=C_YI(cell,mix,0); if (C_T(cell,tf)<=273.15) { m_lg_m=10.0*C_VOF(cell,thread)*C_R(cell,thread)*Wv *(Wv-Wvs)/Wvs; } else if (C_T(cell,tf)>273.15) { m_lg_m=0; } return (m_lg_m); } but there always some errors when the fluent computing, after one step,it stopped. So,there is anybody know how to solve this problem when using DEFINE_MASS_TRANSFER? there is no need to define energy source when using DEFINE_MASS_TRANSFER? Hope someone can give some addvice,thanks ! |
There are functions that need phase level thread but you have provided mixture level threads, such as, C_YI and C_VOF. A good way to ensure is to go to Contour Plots and then check whether a field, such as, species mass fraction or volume fraction appear under phase or mixture. If it appears for mixture, then use mixture thread else use phase thread. Species mass fractions and volume fractions, both, belong to their own phase threads, so, use ice or tf instead of mix as their argument.
Mass transfer must always be accompanied with other transfer of momentum, energy, etc. However, that is taken care of by single UDF. So, you don't need to do anything extra. You may not really need this UDF since you can use Icing simulation in Fluent instead of using your own UDF, provided, icing simulation matches your requirement.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
thanks for your reply. It was really useful. and I want to ask you where I can find the Icing model? or using TUI command to start the model? thanks!
qntldoql
Rep Power: 7 ![]() |
Hi, I am currently doing a similar simulation (humid air > ice). I was wondering how you fixed your UDF? Currently I am using very similar UDF to your's with different equation. But encountering a problem with FLUENT where the simulation does not begin as it states that the executable is only for post-processing.
May I ask how you addressed this particular section of your UDF run the simulation? Wv = C_YI(cell,thread,0); m_lg = gamma* C_VOF(cell, thread) * C_R(cell, thread) * Wv * (Wv - Wvs) / Wv; Last edited by qntldoql; January 29, 2021 at 17:17. |
Samarth Kathare
Rep Power: 0 ![]() |
I am modeling a frost formation problem on a cylinder. I am wondering if someone can share their UDF and how to implement it in Fluent?
Aneesh
Rep Power: 3 ![]() |
I am also trying to do the same simulation for the study purpose. It would be helpful
for me if any one send the updated udf code to mail (aneesham7589@gmail.com). |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Heat of formation in Fluent density based solver at 0 K | mkh_sakr | FLUENT | 0 | September 24, 2019 14:31 |
| Enthalpies: Am I confused or is OpenFOAM? (rel. standard vs. enthalpy of formation) | KarenRei | OpenFOAM Running, Solving & CFD | 8 | November 10, 2016 19:18 |
| Pressure BCs or Periodic BCs for model of frost on vertical surface? | andy.eco | FLUENT | 2 | March 26, 2010 03:02 |
| Frost formation | Olo | FLUENT | 1 | May 26, 2009 04:18 |
| Frost Formation on Evaporators | Ahmad | FLUENT | 0 | September 5, 2005 14:54 |
