May 29, 2020, 09:13 |
question about iteration
shayan
Rep Power: 7 |
I am simulating flow around hydrofoil in fluent.
Coefficient of Lift stop at 450 iteration but I want to continue calculation of Lift until its magnitude become constant. as you can see in below picture it is increasing and it isn't constant when calculation stop. also my number of calculation is 2000. |
May 29, 2020, 09:38 |
Residuals
This happens when the residuals reach the set level. Either disable convergence check based on residual or reduce the set values for residuals.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
pimpleDyMFoam computation randomly stops | babapeti | OpenFOAM Running, Solving & CFD | 5 | January 24, 2018 05:28 |
Free surface issues with interDyMFoam for hydroturbine | oumnion | OpenFOAM Running, Solving & CFD | 0 | October 6, 2017 14:05 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 02:50 |
iteration in solver | wlt_1985 | FLUENT | 0 | September 21, 2011 04:48 |
Parallel runs slower with MTU=9000 than MTU=1500 | Javier Larrondo | FLUENT | 0 | October 28, 2007 22:30 |
