temperature as output parameter
Old   June 15, 2020, 08:47
Default temperature as output parameter
Lukas
lukas' is on a distinguished road
Hey!
For my current project I want to analyse the temperature at special points for different input heat power values. I found out that I can set a parameter in Fluent for my heatet body so that I can change the power systematicly. I can change the parameter sets in Workbench.
What I still need is to set an output parameter. I want to set some points and the output parameter should be the temperature at that points. Where can I set the points and read out its temperatures? Can I do this in Post-CFD?
Thanks in advance an best regards!
lukas' is offline   Reply With Quote
[swak4Foam] outputTime in Swak function immortality OpenFOAM Community Contributions 20 October 6, 2022 12:08
Scheme - output temperature as an input + increment rydol Fluent UDF and Scheme Programming 4 January 9, 2020 06:47
How To Get A value in C In An Output Parameter Based On An Expression In CFD-Post Shomaz ul Haq CFX 2 April 25, 2016 13:17
Output Parameter M4x1m ANSYS 1 November 13, 2014 15:15
Accessing output parameter value in scheme nnvoro Fluent UDF and Scheme Programming 1 October 11, 2014 14:53
