fluid specific heat and thermal conductivity in porous zone
Old   June 15, 2020, 03:39
Default fluid specific heat and thermal conductivity in porous zone
Weiqiang Liu
Weiqiang Liu is on a distinguished road
Hi all,
I am modeling a hydrogen combustion in porous media. Actually, I am trying to reproduce results in literature. In literature, Specific heat and thermal conductivity of gas mixture are used to calculate Pr number.
In my udf code , I used C_CP(c,t) and C_K_L(c,t) to access cell specific heat and thermal conductivity. However, I know cell specific heat and cell thermal conductivity are volume averaged in porous zones. Therefore, my question is:
Should I access cell value of specific heat and thermal conductivity values first and then use volume averaged method to get gas mixture specific heat and thermal conductivity. These are the right values I should use in UDF instead of directly accessed cell values?
Best regards
Weiqiang
Weiqiang Liu is offline   Reply With Quote
Old   June 15, 2020, 05:00
Default Averaged Values
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
What do you mean by
If you're implying that Fluent uses averaged values, then that's incorrect. However, you are applying averaged values, then it is a different matter. Otherwise, each cell has its own value.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   June 15, 2020, 05:11
Weiqiang Liu
Originally Posted by vinerm View Post
What do you mean by
Hi Vinerm,
I can't really understand your answer. I am not a native English speaker. Actually, I used UDS to solve porous solid matrix energy equation and the porous thermal model is kept as thermal equilibrium.
My confusion is if I keep the default thermal equilibrium model, then fluent will use volume averaged method to solve energy equation for fluid. However, I also defined enthalpy source term for fluid and solid as well. Am I solving energy equation of fluid twice?
Should I just select non equilibrium thermal model and then set all heat transfer coefficients in fluent panel to zero. Then defined my own enthalpy source for both fluid and solid.
I think this is reasonable. Am I right?
Best regards
Weiqiang
Old   June 15, 2020, 05:21
Default Energy Equation in Solid
vinerm's Avatar
Vinerm
Equilibrium model assumes that the temperature of solid and fluid in each cell is same. That does not mean the properties are homogeneous or same. Just for the heat conduction part, weighted-average properties are used. If you use non-equilibrium model with HTC 0, that implies adiabatic boundary condition. Do you want no heat transfer between the solid matrix and the fluid? Then, you can do that. Otherwise, enable non-equilibrium model. But just check for the compatibility of the non-equilibrium model with combustion models; it may not be available for all of those.
Don't worry, I'm not a native English speaker as well.
Regards,
Vinerm
Old   June 15, 2020, 05:41
Weiqiang Liu
Hi, Vinerm,
I do want to model heat transfer between fluid and solid. However, if I select non equilibrium with HTC 0, I just disable the heat transfer defined by fluent solver. I can still use enthalpy source term to model heat transfer between fluid and solid.
Best regards
Weiqiang
gas mixture, porous media, specific heat, thermal conductivity, volume averaged
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 21:43
Domain Reference Pressure and mass flow inlet boundary AdidaKK CFX 75 August 20, 2018 05:37
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Simple piston movement in cylinder- fluid models arun1994 CFX 4 July 8, 2016 02:54
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
