Larissa Lemos
Rep Power: 7 ![]() |
Hi! Anyone know if fluent has a Macro for rms temperature? Modeling turbulent combustion the rms temperature is available as a result, but I want to use the information in one UDF. I did not find this on the manual.
Thank you! |
It depends on the combustion model. If you are using PDF, then you can try to use SV_T_RMS. It is defined, but whether available for UDFs or not, I am unsure.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
Larissa Lemos
Thank you for answer. I am using PDF model, but is a steady state simulation and I think that SV_T_RMS works in transient solutions. I tried to use but the result is a single value for all the domain. Not a field of rms temperature. The PDF model provide this field of rms temperature as a result, so I think it would be possible to use.
Transient RMS are usually not saved in data file, but you are most likely right because its used in unsteady.h. As far as PDF based RMS is concerned, I don't see any such variable.
There is a way to fetch any variable that is available in Contours, but I don't remember it right now. However, I am sure that it exists and you might find it either on this forum or online.
And there is a function called Calc_Pdf_RMS that requires three arguments. First and second are standard cell_t and Thread but third one is an integer. In my view, that might corresponds to the index of the RMS variables. So, if you want temperature, then you have to use the index as given in list when it displays in Contours. It returns a real value corresponding to that cell.
Larissa Lemos
Thank you again, I tested Calc_Pdf_RMS(c,t,integer number) and the function return the rms value of mass fractions, according the index of species.
I think I am close to finding the rms temperature. |
Junjun Guo
Rep Power: 8 ![]() |
Hi Larissa,
Did you find the way to get the RMS temperature in UDFs? I face the same issue. Thanks Junjun |
Larissa Lemos
Hi! No, I still have not. I am using the PDF model for non-premixed combustion, so now I am trying integrating the temperature in PDF function. I am doing something that is ready, so it is the double of work, but I asked this question for many people and no one knows a macro for rms temperature. If I find I will write here, if you find could you do the same? Thanks!!
#9 | |
Junjun Guo
#10 |
Larissa Lemos
Yes, it really works!!! When I tested I think it was only for species, but the last one is rms temperature! Thank you so much!
What do you mean, do you want to know how is calculate the rms temperature? Thank you!! |
#11 | |
Junjun Guo
In this post, they guess the rms in Fluent is not the genuine RMS as we normally learned. Do you know the equation used to calculate the rms in Fluent? |
#12 |
Larissa Lemos
Actually I am testing this, I think the result of rms temperature is only about the fluctuating part, as commented in the post for velocity. However, I don't found this explication on the manual.
#13 |
Krutika Appaswamy
I have been trying to obtain the RMS of temperature (PDF method for combustion calculations) but the RMS temperature's XY plot is much lesser than expected. I read a couple of posts explaining the reason being it is the RMS of the fluctuations. I was wondering if there is any way to obtain the actual RMS values. Thanks! |
macro, rms temperature |
Display Modes | |
fvOptions | npatricia | OpenFOAM | 6 | May 23, 2018 05:21 |
outlet temperature | jigneshrohit99 | FLUENT | 1 | March 25, 2016 13:26 |
Free stream temperature | saharesobh | FLUENT | 1 | October 11, 2012 20:52 |
Bulk temperature Tf is obtained from total or static temperature? | NPU_conanxie | FLUENT | 0 | March 30, 2011 05:56 |
