DPM Injection Material droplet
Old   July 9, 2012, 13:46
Default DPM Injection Material droplet
manuel
manuels is on a distinguished road
i want to use DPM-Model for spray simulation. If i select injection i cannot set droplet as material type, which i need? In the user guide they say that the material type Droplet can only be set by heat transfer processes. I can only chose for material type massless and inert. Does some have any idea how i can get droplet without using heat transfer process.
I need droplet as material type because i want to inject liquid water.
This is my first post. Can someone help me please? I will reciprocate to you if i can!
Greetings
manuels is offline   Reply With Quote
Old   July 11, 2012, 03:44
manuel
Does anybody have any idea?
Old   July 11, 2012, 04:34
thuhangbk48 is on a distinguished road
you can choose the droplet option, then you choose any kinds of material in the up-down list. This material will appear on material window, you turn back material and setting and edit material as what you want (of couse, you do not change the name, you change only the physical properties)
thuhangbk48 is offline   Reply With Quote
Old   May 29, 2015, 08:02
Rob V
Robb13 is on a distinguished road
From the FLuent user guide:
The droplet type is available when heat transfer is being modeled and at least two chemical species are active or the nonpremixed or partially premixed combustion model is active.
So you just have to turn on the energy equation and enable species transport.
Robb13 is offline   Reply With Quote
Old   July 2, 2016, 05:12
Smile
James
Tensian is on a distinguished road
Robb is true. Just turn on species transport and you will be able to choose Droplet particles.
I am having another problem related to this. I need to inject water droplets and see how they evaporate. But under the droplet material I cannot choose water (in evaporating species I am able to select water vapor).
I wabt to solve the cooling of a metal piece using DPM. Continuous phase is fluid and disperse phase is water. So I guess my mixture under species transport is water+air and I will need to consider water droplets with water vaporu fromation (Evaporating species in DPM)
Any hint of what could be the reason of my problem? Why I cannot select water as droplet material in Injections tab?
Thanks in advance!
Tensian is offline   Reply With Quote
Old   July 1, 2020, 06:11
BryceLos is on a distinguished road
Hi Robb,
I enabled species transport, but still cannot select the "droplet" type. You have some suggestions?
Thanks,
Bryce
BryceLos is offline   Reply With Quote
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
error message cuteapathy CFX 14 March 20, 2012 06:45
Dense DPM Injection Help (basic sedimentation) sgelman FLUENT 0 July 21, 2010 14:19
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 12:02
