June 25, 2020, 15:58 |
Convergence problem
Felipe Silva Maffei
Rep Power: 10 |
Hello everyone!
It is the second time that I have posted something on this forum, so, if I doing anything wrong, sorry. That said, lets to my question: I am trying to simulate an incompressible jet pump. The boundary conditions was setup as normal velocity equal 1 m/s at secondary and primary inlets. At the outlet, it was used the outlet-pressure with reference pressure equal to zero and the wall with no slip conditions. The turbulence model used was the RNG k-epsilon. The mesh was built in the ICEM CFD using the structured type (finer elements was positioned near the walls). I am using the SIMPLE solver with: Gradient -> Green Gauss node based Pressure -> Linear Momentum, and tubulenty properties -> First order URF -> fluent standard I already try a lot of configuration, but I cannot avoid the behavior that is shown in the figure 1, thus, the residuals do not decrease. Way is it happen? Fig1 -> Velocity field with the error highlighted with red line Fig2 -> Mesh detail 1 at this region Fig3 -> Mesh detail 2 at the region |
June 26, 2020, 08:32 |
André
Rep Power: 10 |
what are the residuals showing?
Is that first plot velocity or residuals? looks like velocity to me...
Sapere aude! |
convergence failure |
Display Modes | |
Convergence problem in Fluent for quenching process | kaeran | FLUENT | 4 | December 1, 2014 02:14 |
Rotate frame reference convergence problem! | wjy-c | CFX | 2 | September 26, 2014 06:03 |
Centrifugal pump OpenFOAM, convergence problem, ANSA model | RDD | OpenFOAM Running, Solving & CFD | 0 | July 5, 2014 09:12 |
Convergence Problem in Axisymmetric Periodic Flow | atheresia | FLUENT | 3 | February 10, 2014 03:00 |
Convergence of CFX field in FSI analysis | nasdak | CFX | 2 | June 29, 2009 01:17 |
