user defined mixing law for thermal conductivity |
June 25, 2020, 10:27 |
Weiqiang Liu
Rep Power: 9 |
Hi all,
In ANSYS_Fluent_Users_Guide, it says user-defined and user-defined-mixing-law can be used to define thermal conductivity of mixture. The difference between these two methods is that user-defined-mixing-law can specifiy thermal conductivity of individual species. User_Guides also says that if ideal gas law is used, the solver will compute the mixture thermal conductivity based on kinetic theory. Otherwise, mass fraction average of the pure species will be used to calculate mixture species. I am wondering is the essence of user-defined-mixing-law to define thermal conductivity of individual species in UDF source code and let fluent solver decide mixing law? Actually, User-defined-mixing-law has nothing to do with mixing law. Instead, it's about defining thermal conductivity of individual species? Best regards Weiqiang |
June 25, 2020, 10:35 |
User Defined Mixing Law
You have got it other way around. A user-defined mixing law is to define properties of the mixture, not of the individual species. A mixing law does not apply to a pure material.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
June 26, 2020, 07:23 |
#3 | |
Weiqiang Liu
Rep Power: 9 |
Thanks for replying. it suddenly comes to me mayby the divergence happened previously when I used generic_property is because I hooked my UDF to user-defiend instead of user-defined-mixing-law. If I hooked my udf to user-defined-mixing-law, maybe divergenc won't happen anymore. Best regards Weiqiang |
thermal conductivity, user-defined, user-defined-mixing-law |
Assigning source terms in user defined memory which is located at the interface? | vidyadhar | Fluent UDF and Scheme Programming | 0 | November 20, 2018 08:06 |
[General] Paraview User defined view | prapanj | ParaView | 3 | January 3, 2014 20:54 |
Creating new user defined material | Vidya | FLUENT | 4 | August 26, 2013 09:26 |
OpenFOAM static build on Cray XT5 | asaijo | OpenFOAM Installation | 9 | April 6, 2011 12:21 |
user defined turbulence model | manuutin | STAR-CD | 5 | October 14, 2009 05:29 |
