June 2, 2020, 05:54 |
How to specify curved piston motion
Abdullah Jamil
Rep Power: 5 |
I want to do cold flow cfd analysis of a curved cylinder engine. The piston oscillates in the curved cylinder. In ICE (Fluent) module, we specify cylinder linear faces, but it is for linear piston motion. How can I specify the cylinder curved face or curved path for the piston to follow with each crank angle? Kindly have a look at the attached image of the curved cylinder engine.
June 2, 2020, 06:05 |
Curved Piston
You can do this, however, the system is physically useless if the piston is rigid. How do you expect a rigid face, the crown of the piston, to cover two multiple distances? The distance to be traveled by the sides close to higher curvature is much less than those close to lower curvature. So, the piston will move, but the stroke cannot be long enough to be useful.
Regards, Vinerm PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority. |
June 2, 2020, 06:13 |
#3 | |
Abdullah Jamil
Rep Power: 5 |
But I dont know how to apply this condition in Fluent for piston motion. Please let me know about it. Thanks in advance! |
June 2, 2020, 07:20 |
Motion
This does make sense.
As far as motion is concerned, you just need to give angular motion and not linear one. If you use Dynamic Mesh, then piston will be a rigid body with C.G. at the center of rotation and motion will be angular one without any linear motion.
July 9, 2020, 01:17 |
Define Dynamic Mesh for Piston
Abdullah Jamil
Rep Power: 5 |
Kind regards.
cfd, cylinder, engine, fluent, piston |
Sinusoidal motion of piston inside cylinder (issue) | Muhamad_Eldebawy | FLUENT | 0 | April 27, 2018 15:11 |
How to use "translation" in solidBodyMotionFunction in OpenFOAM | rupesh_w | OpenFOAM Running, Solving & CFD | 5 | August 16, 2016 04:27 |
External management of solid motion (using dynamicmesh) | maxou1993 | Main CFD Forum | 0 | July 28, 2015 11:37 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
simulation of piston motion inside a hydraulic cylinder | mosman | Main CFD Forum | 0 | August 7, 2011 01:40 |
