April 20, 2022, 03:29 |
contact region
Rep Power: 4 |
I am simulating heat tranfer via a hot air stream through a steel pipe which is enclosed by water. The steel pipe has vertical tubes to increase heat transfer from the air to the water. I used a non conformal mesh so that I can mesh the tubes in detail without having a lot of cells in the water region. I also modeled the thickness of the steel pipe as a seperate zone. I see I get a lot of so called contact regions under boundary conditions in Fluent, which in fact are walls. I run a simulation and heat seems to be transported because the air is cooled flowing through the pipe. However, when I look at the thermal boundary condition of the contact regions it has the default heat flux = 0 value. How is it possible there is heat transfer. Should I use System coupling in stead? It is very confusing to me what is going on here, what is exactly this contact region? |
Interface Contact Region | Najiha Ridzuan | ANSYS | 0 | January 23, 2022 22:00 |
Field Function specified in certain region - Problem with mass fraction | tcr2231 | STAR-CCM+ | 1 | November 26, 2021 04:28 |
[ANSYS Meshing] body of influence vs. contact region | Diger | ANSYS Meshing & Geometry | 5 | October 10, 2018 07:41 |
conjugate heat transfer in OpenFOAM | skuznet | OpenFOAM Running, Solving & CFD | 99 | March 16, 2017 05:07 |
Taking too much for run | Grimoli | OpenFOAM Running, Solving & CFD | 5 | November 26, 2013 20:07 |
