July 10, 2020, 07:45 |
Fluent Laminar Natural convection
amiraladama
Rep Power: 5 |
Hello all, I am doing exercise to improve my CFD skills. I want to ask a question. My boundary conditions; bottom wall hot, top wall cold and side walls adiabatic. My material is air and set as Boussinesq.My temperature difference is 10 and Ra=10^5. My analysis (left picture) as you see rotates counterclockwise but the other picture which has the same conditions (Boundary conditions, Rayleigh Number, Material as air ) except the geometry shape but it is not big deal, the picture(right) spreads from the middle of the bottom wall. What is the reason for this?
I used default SIMPLE Method also I tried different methods like Coupled PISO etc. and I opened the specified operating density then closed but there didn't any changing. |
July 10, 2020, 15:23 |
Lolita
Rep Power: 9 |
What about the surface tension
July 10, 2020, 15:59 |
amiraladama
Rep Power: 5 |
Thank you for your interest but actually, I have no idea about surface tension. There is not a specific description about surface tension and also this is single phase.So I think the surface tension is default or not open right now because I didn't anything and I am new at CFD. Can you a little bit explain then I can look at my work and say to you.
Best regards, Alp |
July 10, 2020, 17:21 |
Rep Power: 11 |
rupak504 but surface tension is multiphase only thing.
alpcfd maybe flow pattern depend from initial conditions and both variants are possible. The easiest thing you can do is to model only half of domain - use symmetry. |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 22:56 |
Thermophysical properties for natural convection | Ciefdi | OpenFOAM Running, Solving & CFD | 0 | November 7, 2013 11:44 |
natural convection problem with radiation | jorien | CFX | 0 | October 14, 2011 09:26 |
Natural convection for passive house fluent 6 | Stuttgart82 | FLUENT | 0 | November 30, 2009 11:37 |
Natural convection in Fluent | Tanveer | Main CFD Forum | 4 | May 20, 2008 12:31 |
