Importing pressure of sides of a 3D blade to a 2D surface in ANSYS static strucural |
August 6, 2020, 11:18 |
Andrew
Rep Power: 5 |
I have a rotating blade with a pressure distribution on each side. In static structural I have a shell element (1 surface with 1 direction vector) (this is necessary for my structural model due to very thin geometry) So when I import the 2 pressures I can't assign direction to them. so the resultant pressure is simply the sum of the magnitudes - the direction is ignored. https://imgur.com/a/L0gRSvl Anybody know a way around this? I'm really stuck with this, thanks. |
Display Modes | |
Recursive output of Foam::word in gdb print command | chengdi | OpenFOAM Programming & Development | 1 | July 19, 2017 20:19 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 15:03 |
[ANSYS Meshing] importing a cfd in ansys static structural | nauman55 | ANSYS Meshing & Geometry | 0 | July 23, 2013 08:22 |
[snappyHexMesh] Layers don't fully surround surface | EVBUCF | OpenFOAM Meshing & Mesh Conversion | 14 | August 20, 2012 04:31 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 15:00 |
