External gear pump-turbine
Old   August 8, 2020, 12:05
Default External gear pump-turbine
Me_1989
Me_1989 is on a distinguished road
Recently, I try to simulate an external gear pump which was used as a turbine. I try to use 1DOF rotation as a dynamic mesh for the motion of the gears ( there are two gears including driver and driven gears). I set one 1DOF for the driver and another 1DOF for the driven gears. I also define the angular velocity but unfortunately there is no motion in the preview!
There is a warning which is "Warning: unable to read motion history file".
I would be so grateful if anybody can give me any solution for this?
Best regards
Me_1989 is offline   Reply With Quote
defining angular velocity of an external gear pump Me_1989 Fluent UDF and Scheme Programming 9 August 8, 2020 20:05
Setting up 3D simulation for external gear pump 310toumad FLUENT 2 February 5, 2019 09:12
CGNS Compiling Diego Main CFD Forum 17 December 21, 2014 01:40
External Gear Pump interawe ANSYS Meshing & Geometry 0 April 14, 2009 17:55
3D External Gear Pump Mustafa Ayad FLUENT 1 January 26, 2009 09:55
