August 13, 2020, 13:42 |
Heat Transfer Problem
Hüseyin Can Sülük
Rep Power: 6 |
Hello everyone i have been trying to do an analyse with 3 coper pipe (check addd pics.) which carrying water and there is air outside. here are the requirements
temp of water is 25 air is at the room temp. upper side of pipes gets 1000 W/m^2 heat outer sides of pipes loosing heat through natural convection and radiation and i am interested about water output temp and pipe outer temp. i have created geo. as shown but i dont know how to arrange setup i need help guys |
August 14, 2020, 01:24 |
Alexander
Rep Power: 34 |
whats the point of air zone if you have boundary condition 1000 W/m^2 on pipe surfaces?
best regards ****************************** press LIKE if this message was helpful |
August 14, 2020, 05:53 |
Hüseyin Can Sülük
Rep Power: 6 |
boundry conditions are not completely given i am just trying make it like real life conditions 1000 W/m^2 is just applied the upper side of pipe lower side still losing heat via convection and radiation
August 18, 2020, 01:52 |
Alexander
Rep Power: 34 |
if you want to apply heat flux as boundary condition, you don't need external air in that region
on the other hand you may use volumetric heat source instead, in that case you can have air zone connected to pipes: 1. to some part of pipe directly 2. to shell with artificial thickness, adjusted to part of pipe
August 21, 2020, 04:39 |
JSM
Rep Power: 20 |
I would recommend to do few basic tutorials in heat transfer to understand the set up method. It will accelerate your learning curve.
With regards, JSM |
August 21, 2020, 05:35 |
Hüseyin Can Sülük
Rep Power: 6 |
thank you for your suggestions guys i have completed this simulation at the moment i dont have enough time to upload results but if anyone needs setup or results i can upload it under this thread
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
complex impinging jet heat transfer problem | spelletier | Main CFD Forum | 7 | July 10, 2019 04:31 |
Interphase mass transfer of a reaction | cfx_ws1992 | Main CFD Forum | 0 | May 15, 2017 21:42 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
Heat Transfer Problem Help | JB | FLUENT | 2 | October 18, 2006 18:54 |
