August 21, 2020, 10:11 |
Mesh Motion reference frame directions
Rep Power: 5 |
Hello everyone,
I'm simulating pitching motion of a 3D wing. The model has 2 O-blocks, communicating via mesh interface. The whole inner block, containing the wing, rotates according to UDF that defines the angular velocity which is the input of the block Mesh Motion (pitching is about Y axis). The simulation is converging, but I get some strange values of the coefficients. Moment coefficient is as expected, also Lift coefficient shows reasonable values. As for drag coefficient I get negative values that are the opposite of the expected values. I obtain forces coefficients by projecting X and Z coefficients with respect to the angle of attack at each time step. I get X and Z forces by setting directions as (1 0 0) and (0 0 1) respectively, but I'm not sure whether these directions are inertial to the body, so "rotating" together with the block, or rather fixed with the absolute reference frame. Can anybody help me? Thank you in advance. |
angle of attack, fluent, forces, mesh motion, pitching |
Abnormal result of dynamic mesh motion at the between bottom and side boundary. | blue8803 | OpenFOAM Running, Solving & CFD | 7 | July 2, 2020 05:46 |
Different zone motion and mesh motion preview | aamer | FLUENT | 5 | September 24, 2012 13:58 |
Dynamic moving mesh | Pei-Ying Hsieh (Hsieh) | OpenFOAM Running, Solving & CFD | 64 | June 7, 2012 10:04 |
Prescribed mesh motion does not correspond to actual motion | rbarrett | CFX | 8 | June 30, 2011 13:22 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
