UDF for time-step
Like Tree1Likes
  • 1 Post By p.b+cfd
Old   September 12, 2020, 11:47
Default UDF for time-step
Francesco
franc1 is on a distinguished road
Hi everybody,
i need a UDF for the time-step in which i have to assign 3 different time-steps at 3 different levels, respectively:
from 0 to 1s ---> TS=0.01
from 1s to 3s---> TS=0.004
from 3s to end---> TS=0.1
I tried this way but it didn't work
#include "udf.h"
DEFINE_DELTAT(ts, d)
	real time_step;
	real flow_time = CURRENT_TIME;
	if (flow_time < 1)
		time_step = 0.01;
	if (flow_time > 3)
		time_step = 0.1;
	else
		time_step = 0.004;
	return time_step;
Thank in advance
franc1 is offline   Reply With Quote
Old   September 18, 2020, 06:38
p.b+cfd is on a distinguished road
Try this:
    real time_step;
    real flow_time = RP_Get_Real("flow-time");
#if PARALLEL
    host_to_node_real_1(flow_time);
#endif
    if (flow_time < 1.0)
        time_step = 0.01;
    else if (flow_time > 3)
        time_step = 0.1;
    else
        time_step = 0.004;
    return time_step;
But I guess you have to compile it!
franc1 likes this.
p.b+cfd is offline   Reply With Quote
[solidMechanics] Support thread for "Solid Mechanics Solvers added to OpenFOAM Extend" bigphil OpenFOAM CC Toolkits for Fluid-Structure Interaction 686 December 22, 2022 10:10
time step continuity problem in VAWT simulation lpz_michele OpenFOAM Running, Solving & CFD 5 February 22, 2018 20:50
Stuck in a Rut- interDyMFoam! xoitx OpenFOAM Running, Solving & CFD 14 March 25, 2016 08:09
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 03:50
calling result of a UDF into current time step Komon Fluent UDF and Scheme Programming 1 April 1, 2012 20:53
