Boundary conditions of UDF writing speed changing with time
Old   September 13, 2020, 22:48
Default Boundary conditions of UDF writing speed changing with time
ZengJiChuan is on a distinguished road
The speed changes periodically with time, and UDF is loaded by means of compilation. Fluent is parallel computing, and there are other UDFs. But the recorded data shows that the speed has not changed over time. Please help to see what might be the reason. The following is UDF:
#include"udf.h"
DEFINE_PROFILE(air_inlet_velocity,thread,position)
real t,v,a;
face_t f;
begin_f_loop(f,thread)
t=RP_Get_Real("flow-time");
a=(int)t%240;
if(a>=0&&a<60)
v=(float)a/60+4.63;
else if(a>=60&&a<180)
v=-(float)a/60+6.63;
else if(a>=180&&a<240)
v=(float)a/60+0.63;
F_PROFILE(f,thread,position)=v;
end_f_loop(f,thread)
ZengJiChuan is offline   Reply With Quote
Old   September 15, 2020, 23:01
Dico Nico
Diconico is on a distinguished road
Could it be because you are running in parallel? Maybe, because your domain is solved by diferent nodes, and you are looping in the domain, it is overwriting something, try running in serial, just to see if the velocity changes. When I have more time, I'll give a better look to give you a proper answer.
Diconico is offline   Reply With Quote
Old   September 16, 2020, 03:54
Thank you for your answer. I have found my wrong place. I shouldn't use cast, which causes a to be zero at the beginning.
bash script for pseudo-parallel usage of reconstructPar kwardle OpenFOAM Post-Processing 43 October 28, 2025 04:19
courant number increases to rather large values 6863523 OpenFOAM Running, Solving & CFD 22 July 6, 2023 00:48
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 05:13
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 08:47
