[Sponsors] | |||||
How can I check the results of mass source in Fluent? |
THA SEANGHAI
Rep Power: 7 ![]() |
Hello!In Fluent, I do not know how to check the results of mass source that I input on the cell of the fluid domain. First, I input the constant value of the mass source by going to Set up=> Cell Zone Condition=> choose selected cell=> edit=>enable source terms=> click on source terms tap=>click edit on Mass source=> Number of mass source is 1=>type constant value: 0.001 [kg/m³s]=>Ok. Then go on doing something else=> Finally ran the calculation. But after calculation, where can I check the results of that mass source which I input on the selected cell? Thank you in advance for your help!
Moritz Kuhn
Rep Power: 18 ![]() |
Via Results --> Reports -- Mass Flow Rate. Your Mass source should be the difference between the massflow of your in and outlets.
#3 | |
THA SEANGHAI
So mass source=mass flow rate (outlet) - mass flow rate (inlet), is this what you meant? Sorry if there is anything wrong. I will always appreciate you reply and help! Thanks again! |
Moritz Kuhn
For a steady state solution yes. For transient cases, probably not, depepends on your set up.
THA SEANGHAI
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| [swak4Foam] swak4foam for OpenFOAM 4.0 | mnikku | OpenFOAM Community Contributions | 80 | May 17, 2022 09:06 |
| Mass Source application and strange phenomena | JPBLourenco | FLUENT | 0 | June 27, 2019 09:36 |
| what is swap4foam ?? | AB08 | OpenFOAM | 28 | February 2, 2016 02:22 |
| [foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 22:53 |
| OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 20:08 |
