Non-Equilibrium Heat Transfer in Porous Media Option Grayed Out
Like Tree1Likes
  • 1 Post By srsel6
Old   September 17, 2020, 03:12
Default Non-Equilibrium Heat Transfer in Porous Media Option Grayed Out
srsel6 is on a distinguished road
Hello everyone,
I'm trying to model flow through a porous medium (100s of layers of steel wire mesh). I need to study the transient heat transfer between the porous medium and the hot air flowing past so I'm trying to select the "Non-Equilibrium" option in the porous media options. However, the option is grayed out. I've been looking around but no luck so far, does anyone know what options need to be selected?
srsel6 is offline   Reply With Quote
Old   September 20, 2020, 12:05
Bump, does anyone know the solution to this?
Old   September 20, 2020, 12:24
Hi everyone, in case anybody runs into this problem, I've found the solution. If you're working with a density based solution, you need to set it as a pressure based solution first. Then select the non-equilibrium model and allow Fluent to automatically create the adjacent solid zone. Then, you may change from the pressure based solver to the density based solver.
If you initially select the density based solver before defining the non-equilibrium model, it will be grayed out.
lei likes this.
Table bounds warnings at: END OF TIME STEP CFXer CFX 4 July 17, 2020 00:44
Compression stoke is giving higher pressure than calculated nickjuana CFX 62 May 19, 2015 14:32
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 15:32
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 13:02
