[Sponsors] | |||||
FLUENT defining weird face zones, causing problems? |
Ann
Rep Power: 0 ![]() |
Hi all,
I am working on modeling heat transfer and fluid flow in a plate-fin heat exchanger (aluminum structure with separate channels for air and steam flow). Air flows through the triangular channels and steam through the rectangular channels. Capture.jpg I have successfully (I think) created and meshed the geometry, and have defined named selections for all inlets, outlets, domains and interfaces. However, when I open setup, I receive a series of errors of the following type: Warning: materials in neighbor cell threads (11 and 9) of interior zone 1 are of different types (air and aluminum). This problem MUST be fixed before solving! After some digging, I noticed that fluent seems to have defined an incorrect face zone, shown below. Capture2.jpg Is this what is causing my problem? Can I remove it (or separate the cells that make it up and merge them with their respective correct zones)? Any help would be greatly appreciated and I can provide any more info as needed! |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| [snappyHexMesh] How to define to right point for locationInMesh | Mirage12 | OpenFOAM Meshing & Mesh Conversion | 7 | March 13, 2016 15:07 |
| [mesh manipulation] Importing Multiple Meshes | thomasnwalshiii | OpenFOAM Meshing & Mesh Conversion | 18 | December 19, 2015 19:57 |
| [Commercial meshers] Problems during import of fluent mesh | Lancester | OpenFOAM Meshing & Mesh Conversion | 2 | October 4, 2013 13:44 |
| [Gmsh] Import problem | ARC | OpenFOAM Meshing & Mesh Conversion | 0 | February 27, 2010 11:56 |
| fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
