Missing surface from fluent meshing to solver
3 Attachment(s)
Hello everyone,
I have ANSYS 2019 R2 and I'm having problems using fluent with meshing mode and the watertight workflow, I need to report the torque generated on a rotor, for which I have created a named selection with all its walls in spaceclaim. as you can see inthe attached images. Then, when I am updating the borders in the meshing workflow, I have noticed that the turbine does not appear in the selection by "label" but in the selection by "zone" (I don't know if it is related with my problem or it's normal) Finally, when the mesh is generated and I switch to solution mode, I cannot find the turbine as a wall zone to generate the report of the moment from it. Could anyone help me? Thanks for your attention. Best regards, Johan Betancour Osorio. |
