Setup the reynolds number in fluent.
Old   September 21, 2020, 16:05
Smile Setup the reynolds number in fluent.
CellZone is on a distinguished road
Hello cfdOnline World,
I want to set a constant reynolds number of Re=5*10^6 and a constant mach number of Ma= 0.7 for my simulation in fluent.
So I define: ambient pressure and ambient temperature -- > this gives me my density and I can calculate my velocity from Mach number relation Ma=v/ (sqrt(k*R*T))
With this velocity I go for the reynolds number and NOW I play with the dynamic viscosity and put it on a constant value in fluent. This way I should achieve my desired viscosity
1. Is this correct?
2. How is this done in a wind tunnel experiment? I think they change the ambient pressure but set the temperature constant so that they change the density and this way the dynamic visosity, right?
3. For high Mach numbers the temperature near a body changes. This will effect the density and viscosity of the fluid. Will this also change the reynolds number or is the reynolds number only defined for free stream quantities?
Thank you very much for your help
CellZone
CellZone is offline   Reply With Quote
Old   September 21, 2020, 16:17
So 4. Should I change DENSITY (via PRESSURE ideal gas) or DYNAMIC VISCOSITY in order to match Mach Number and Reynolds Number?
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops avinashjagdale OpenFOAM Meshing & Mesh Conversion 53 March 8, 2019 10:42
Reynolds Number Calculation in Fluent and effect on results mrwts FLUENT 4 December 9, 2015 06:05
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 14:41
decomposePar -allRegions stru OpenFOAM Pre-Processing 2 August 25, 2015 04:58
low reynolds number models in Fluent doug Main CFD Forum 6 August 4, 2012 15:39
