[Sponsors] | |||||
999999 error when running PDF Transport model |
Doug
Rep Power: 0 ![]() |
Hi all,
I was hoping someone might be able to help me with an issue I've been having for a while when trying to run the Composition PDF Transport model to simulate a turbulent combustion problem. Previously I used a different combustion model (EDC) with no issues, however, when changing to the PDF model I get the following error: "999999: mpt_accept: error: accept failed: No such file or directory MPI Application rank 0 exited before MPI_Finalize() with status 2 The fl process could not be started." The weird thing is that this error only occurs when the density is set to "ideal-gas" in the Edit Material panel (i.e. it is fine with either "incompressible-ideal-gas" and "volume-weighted-mixing-law"). I've also tried it with a simplified version of the model using the default mixture template and the same error occurs when setting the density to "ideal-gas" rather than incompressible. I should also mention that this error only occurs when the Lagrangian option is selected for the PDF Transport, and it seems to be fine when Eulerian is selected. It also occurs whether the simulation is run in serial or parallel. I'm not sure if this is a bug with Fluent or there is something I'm doing wrong, but I'd appreciate any help with this, thanks. |
Jinshan Yi
Rep Power: 6 ![]() |
Hello, have you solved it? I have the same problem as you
Jinshan Yi
Anyboday can help, please?
| Tags |
| composition pdf method, error 999999 |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Do we need to enable species transport model or not? | THA SEANGHAI | FLUENT | 0 | August 14, 2020 04:18 |
| Transport model | adrieno | OpenFOAM Pre-Processing | 1 | April 7, 2016 12:18 |
| Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 07:20 |
| question about composition PDF transport model | lisa_china | FLUENT | 3 | November 23, 2014 20:59 |
| 999999 (../../src/mpsystem.c@1123):mpt_read: failed:errno = 11 | UDS_rambler | FLUENT | 2 | November 22, 2011 10:46 |
