November 23, 2020, 23:36 |
solve dimensionless equations in fluent
ashkan
Rep Power: 5 |
I am trying to scale down a large geometry by solving governing equations in dimensionless form. is it Necessary to write a UDF or I can do it without UDF? thanks |
November 24, 2020, 08:55 |
Lorenzo Galieti
Rep Power: 12 |
You should simply adimensionalize your dimensional results rather than solving dimensionless equations. E.G. create a dimensionless velocity as a custom field function V*= V/Vref and then plot that one
Or you simply scale the mesh down. I don't see the point in solving the dimensionless equations |
November 24, 2020, 15:35 |
Lucky
Rep Power: 65 |
Yeah. Fluent solves dimensioned equations. You have to non-dimensionalize it yourself using some kind of workaround.
Probably the easiest way is to scale down your geometry and boundary conditions and everything so you have the same dimensionless parameters. Refer to the Buckingham pi theorem if you are unsure how to do this. |
How to solve an algebraic system of equations | agustinvo | OpenFOAM Programming & Development | 2 | July 14, 2020 13:42 |
Write a solver to solve the Fithigh-Nagumo equations | Alex1418 | OpenFOAM Programming & Development | 0 | December 14, 2014 17:24 |
simultaneously solve number of diffusion equations | Shakil Masum | OpenFOAM Running, Solving & CFD | 5 | August 29, 2014 05:02 |
Does FLUENT 13.0 use the Favre averged Navier-Stokes equations ? | conim | FLUENT | 0 | August 21, 2012 02:29 |
Can FLUENT solve this type of problem? | Whitaker | FLUENT | 3 | October 23, 2000 03:01 |
