November 16, 2020, 13:31 |
Fluent UDF problem after transfering files
Marcin
Rep Power: 9 |
Hi everyone,
I transferred all the files - case and data, journals, udf's and so on (the whole folder), to another computer, where I would like to perform postprocessing. However, I have some issue, which precludes automatic postprocessing using journals. The problem is shown below: I tried to use TUI commands: define user-def auto-comp no q q q but it did not help. I dont need to have working udfs in this case, I just need to do postprocessing. Please write if you have any idea how to fix it Regards |
November 16, 2020, 22:53 |
Alexander
Rep Power: 34 |
error says that your UDF functions (profiles) are not found.
you may ignore it for postprocessing only or recompile UDF and load it again
best regards ****************************** press LIKE if this message was helpful |
November 17, 2020, 01:07 |
Marcin
Rep Power: 9 |
@Alexander yeah I get it, but this error and popup window makes my journal doesnt work as you can see in the picture
So I have to do sth with it |
November 17, 2020, 01:31 |
Alexander
Rep Power: 34 |
problem comes from journal, these errors should not influence
November 17, 2020, 08:18 |
Marcin
Rep Power: 9 |
Yes youre right it turned out that despite the popup window everything works fine and I can read the subsequent case and data files to postprocess different things.
But I would like to ask for the future, how could I solve the problem with these udf's that are not compiled automatically? EDIT: Now I tested the journal and unfortunately it works only once, I mean - if I use journal for two or more case and data files it stops working after the first case and data. I tested the journal on the another computer and it works fine so journal is correct. Thus, I have to fix described problem Last edited by destroy; November 17, 2020 at 12:19. |
November 19, 2020, 00:15 |
Alexander
Rep Power: 34 |
How to solve UDF compilation problems in Fluent. | pakk | Fluent UDF and Scheme Programming | 16 | September 10, 2018 02:48 |
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM | Rizwan | Fluent UDF and Scheme Programming | 40 | March 18, 2018 06:05 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 13:41 |
UDF Compilation Error - Loading Library - COMMON Problem! Help! | robtheslob | Fluent UDF and Scheme Programming | 8 | July 24, 2015 00:53 |
critical error during installation of openfoam | Fabio88 | OpenFOAM Installation | 21 | June 2, 2010 03:01 |
