Multiphase and Species models interaction
Old   December 2, 2020, 17:01
Default Multiphase and Species models interaction
Lima
nmontalbetti is on a distinguished road
Hello, I'm having trouble defining a volumetric reaction function while using the multiphase model.
Accoding to Fluent's User's Guide, the proper way of defining a reaction while using the VOF multiphase model is to do it through "Phase Interactions". However, when I enter the "Phase Interactions" tab and select "Reactions", I can define the reactants and products, but I can't choose a Reaction Rate Function, the only option is "none".
The only models turned on in this simulation are the multiphase model and the species model. I'm modelling a microreactor and I've already ran simulations with just the VOF model activated with no problems.
This problem has occured both in Fluent 18.2 and 20.2.
nmontalbetti is offline   Reply With Quote
Old   December 14, 2021, 22:16
dsfdsgvd
kevinllll is on a distinguished road
I simulate multiphase flow reaction by VOF model in Fluent.The first phase is liquid phase and the second phase is a gas mixture.Mass transfer defines that the liquid phase evaporates into gas, and the gas reacts with oxygen.I open species model>>species transport>>volumetric reaction to define reaction in gas mixture.But the calculations diverge at once.In multiphase>>phase interaction>>Heterogeneous Reactions,the volume reaction in the gas phase can also be defined here.I don't know if I set the reaction in the wrong place
kevinllll is offline   Reply With Quote
Is the built-in NOx model of Fluent not compatible with the multiphase flow models? swtbkim FLUENT 1 October 21, 2020 23:12
Species Transport with Multiphase flow in FBR venkat FLUENT 1 July 24, 2008 00:53
Multiphase + Species reactions for wall surface ?? Luke FLUENT 1 June 25, 2006 10:07
Species Transport with multiphase flow Gopal Kasat FLUENT 3 July 12, 2005 19:59
Multiphase and species Models Chico FLUENT 3 July 14, 2004 21:37
