-   FLUENT (https://www.cfd-online.com/Forums/fluent/)
-   -   Wind tunnel contraction turbulence intensity fluctuations (https://www.cfd-online.com/Forums/fluent/232390-wind-tunnel-contraction-turbulence-intensity-fluctuations.html)
Dasun December 12, 2020 02:48
3 Attachment(s)
I am fairly new to using Ansys fluent and currently trying to simulate the flow inside a subsonic low speed wind tunnel contraction. I have created the 3D model using Solidworks and used a hexahedral mesh with edge sizing done to create a finer resolution near the boundary. I used a SST K-w model and specified the velocity of the velocity inlet and pressure of the pressure outlet. I specified the turbulence intensity of the inlet to be 1%.
However, the result from the simulation generates a relatively high turbulence intensity at the contraction outlet. And I tried to recreate a research paper finding and ran to the same problem of high turbulence intensity.
I have attached the results I obtained in my simulation.
Can anyone shed any light on this matter ?
Thanks in advance.
