Lower Lift coefficient value
Old   December 12, 2020, 02:05
Default Lower Lift coefficient value
goutamp is on a distinguished road
Iam carrying out 2D unsteady simulations of single circular cylinder in Fluent with air as working medium, with Pressure based transient solver.
The drag and lift coefficient are not matching with the reference journal values for Reynolds number of 1.3E4, the reported values are drag coefficient as 1.03 and lift coefficient around 0.8.
Whereas for 2D steady state simulations of single cylinder, drag coefficient is 1.03 and lift coefficient is 0.2 is obtained from simulations.
Below are the setup details in fluent
Details :
1) Domain size : 100x30cm
2) Meshing done in ICEM CFD.
3)Reference values:
Diameter of cylinder(d) -- 0.01m
Area (=Pi*d*d/4) = 7.8525e-05 m2.
Length and Depth = 0.01m
5)Boundary conditions:
Inlet velocity - 20m/s
Outlet - zero gauge pressure
Please provide suggestions, to match the drag and lift values for 2D and 3D cases.
goutamp is offline   Reply With Quote
Old   December 12, 2020, 04:53
Ajiazi
Aijiazi is on a distinguished road
Originally Posted by goutamp View Post
Details :
3)Reference values:
you can put the value of diameter in the area and length
Aijiazi is offline   Reply With Quote
Old   December 12, 2020, 08:09
duri
duri is on a distinguished road
The lift coefficient in the cylinder is too high. What is the source of circulation. Since this is an unsteady which quantity are you trying to match, is it average. What about time variation of lift and drag.
duri is offline   Reply With Quote
Old   December 12, 2020, 16:31
Ajiazi
yes
while calculating time histories for force coefficients, fluent uses reference area, for your case you have a cylinder, you can put cylinder diameter in reference area dialog
turbulence models and lift coefficient for naca 0021 Nick R CFX 7 November 29, 2022 16:51
How can i get the resonable drag and lift coefficient in fluent? blivurmind FLUENT 0 September 1, 2020 22:27
Airfoil Coefficient of Lift and Drag - Published Data vs CFD Results Mick2450 CFX 4 April 23, 2020 19:18
Lift and Drag Coefficient too low on airfoil simulation diogoncsa FLUENT 0 October 23, 2019 11:23
Lift coefficient in Eulerian multiphase model hennas FLUENT 1 July 4, 2011 16:50
