How should the aerogel material be defined in the fluent? |
November 18, 2021, 10:03 |
Alluna
Hello there ,
I will use the aerogel material for a cooling analysis that I will perform in Fluent. Although aerogel is a solid material, it has a very porous structure, but I cannot choose a solid material as porous in fluent right ? Is there anyone who can help with this? Cooling analysis tries to measure conduction heat transfer and determine how long the aerogel will protect the box from high temperature. |
November 18, 2021, 13:57 |
Hello Alluna,
Yae you can't define the solid material as porous in fluent. Aerogel is the lightest solid, however you need to consider under fluid regions in Fluent. What really matters for porous zone, as how you define the inertial and viscous terms. Good luck |
November 19, 2021, 00:52 |
Alexander
Rep Power: 33 |
in other words you may try to model it as a fluid with huge viscosity.
in addition you may apply porous zone
best regards ****************************** press LIKE if this message was helpful |
November 19, 2021, 04:02 |
Alluna
Many thanks to both of you, these ideas were really helpful.
aerogel, conductive zones, heat transfer in fluent |
Display Modes | |
CFX error (Overflow) with particular user defined material | UsamaQ | CFX | 8 | April 10, 2020 13:18 |
Will fluent update temperature automatically when enthalpy in every cell is defined? | Weiqiang Liu | FLUENT | 0 | September 16, 2019 13:22 |
Add Young's Modulus and Poisson Ratio to a material into Fluent | florian.crepin | Fluent UDF and Scheme Programming | 4 | April 30, 2019 14:04 |
Domain Reference Pressure and mass flow inlet boundary | AdidaKK | CFX | 75 | August 20, 2018 06:37 |
Compression stoke is giving higher pressure than calculated | nickjuana | CFX | 62 | May 19, 2015 14:32 |
