Defects in surface imprint
Hi everyone,
I'm running simulations on a geometry with side-holes. In post-processing I want to evaluate some parameters on the single side-hole, to do so I am loading the stl surface in Fluent and then I am doing the surface imprint. Problem is that when I do this on a curved surface I get some defects as shown here: https://i.postimg.cc/5NgTspry/tappi-uniti-zoom.png This only happens on the inner side, while if I do the same on the external side everything is fine: https://i.postimg.cc/zfCnk2dP/tappi-esterni.png Does anybody know how to solve this and why it happens? Thank you in advance |
Unfortunately, I can't help you with your problem. I happen to have a pretty similar problem and wanted to know if you were able to find a solution to it? |
