Plotting against Crank Angle Degrees in fluent
Old   February 18, 2021, 13:29
Default Plotting against Crank Angle Degrees in fluent
Timothy
goldencatto is on a distinguished road
Hi, I’m trying to simulate a 60-degree sector mesh of a light duty diesel engine using FLUENT. I am using non-premixed combustion with pilot, main, and post injections. I need help on plotting the Pressure against Crank Angle Degrees but in the “Report Plot” under “Monitors”, there are only options for against flow-time or time step on the X-Axis label.
May I know how can I specifically ask FLUENT to plot against Crank Angle Degrees? Thank you in advance.
goldencatto is offline   Reply With Quote
Crank angle for peak swirl ratio value is not matching.. kazuki FLUENT 0 January 18, 2017 01:44
streamlines of S809 airfoil at Angle of attack of 14 degrees mohammad CFX 1 September 15, 2012 07:02
few quesions on ANSYS ICEMCFD and FLUENT Prakash.Paudel ANSYS 0 August 12, 2010 12:07
About velocity angle when plotting a contours wateraction FLUENT 0 July 24, 2010 23:24
Plotting of lift coefficient vs angle of attack?? John Main CFD Forum 1 August 18, 2003 09:31
