February 19, 2021, 07:16 |
Emissivity doesn’t save
Rep Power: 5 |
I am new in fluent. My work is to make a steady state heat transfer without convection. Everything is fine until I need to save and close fluent. When I then open the same case, only emissivity isn’t saved in boundary condition. I have multiple walls with radiation heat transfer and every time I close fluent the emissivity is set to 1. Also I can’t copy emissivity from one wall to another like with other boundary condition. Have anyone the same issue? I am using Fluent 2020 R2 |
boundary condition, copy, emissivity, saving |
Very quick - Journal file command to save monitors | lcaBR | FLUENT | 2 | October 18, 2022 12:26 |
Odd results with solar load | me3840 | OpenFOAM Running, Solving & CFD | 2 | January 11, 2022 05:07 |
save to variable filename inside loop | FrankR | Fluent UDF and Scheme Programming | 5 | January 30, 2019 11:16 |
[General] Save Animation Settings | TomBot | ParaView | 2 | August 26, 2017 07:54 |
Save Location of Journal Files in TUI | htfl24 | FLUENT | 0 | September 11, 2016 19:26 |
