How to control number of particles entering the domain with DPM model |
January 18, 2021, 07:14 |
Dnyanesh Mirikar
Rep Power: 6 |
I have the mass of droplets injected, the duration for it is injected, and diameter range, mean diameter for rosin-rammler distribution.
How can I control the number of particles injected in the domain for a given time period? From mass and density, I can calculate the total volume of droplets injected. If I divide it by volume of the droplet of the mean diameter, I'll get the number of droplets injected, right? Now in unsteady simulations, fluent is injecting particles at every time step. And these numbers are way greater than what I'm getting from the above calculations. What mistakes I'm making? Thanks in advance. |
January 18, 2021, 12:24 |
Rep Power: 26 |
I don't know, but I do know it would help a lot to show your calculation. If it's wrong, somebody might set the mistake.
March 2, 2021, 04:32 |
ahmed elbanna
Rep Power: 9 |
recommend you refer to documentation published by Ansys Fluent including the theory guide and user guide as they correlate the different models with the recommended operating range.
i have used DPM to simulate dilute flow at low ST you can refer An experimental and theoretical study on particles-in-air behavior characterization at different particles loading and turbulence modulation https://doi.org/10.1016/j.aej.2019.04.002 |
diameter distribution, dpm, mass flow, particle injection |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 14:32 |
[blockMesh] --> foam fatal error: | lillo763 | OpenFOAM Meshing & Mesh Conversion | 0 | March 5, 2014 10:27 |
convergenceof natural convection prob. in cfx | cpkewat | CFX | 15 | January 31, 2014 06:29 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
