December 12, 2018, 07:15 |
Interface behaves like wall
Maximilian Neuenschwander
Hello Everybody,
I am simulating a gas engine with ANSYS Fluent Version 18.2. To avoid remeshing I generated the cylinder as a structured mesh (to be able to layer the movement of the piston). Actually i have six different interfaces on one plane/level, as you can see in the picture (I just left one interface out). When I start a cold-flow simulation, the piston starts to move and the temperature changes, the interfaces behave like a wall (see the temperature-picture). The support just give me hint to use the following command: (rpsetvar 'nonconformal/smallest-area-tolerance-factor 0.005) But changing the parameter did not solve the problem... I hope somebody can help me! Best regards, Max |
March 17, 2021, 01:27 |
Rep Power: 10 |
Hi everyone,
I'm facing a very similar problem. Does anyone know the solution? Sometimes the interfaces work and sometimes they don't. I've checked the settings many times and they're always the same. Any ideas? |
engine, fluent 18.2, interface problems |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Waterwheel shaped turbine inside a pipe simulation problem | mshahed91 | CFX | 3 | January 10, 2015 11:19 |
Setting rotating frame of referece. | RPFigueiredo | CFX | 3 | October 28, 2014 04:59 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
