April 8, 2021, 05:50 |
Multiple Inlet in Fluent
Ravikumar Madineni
Rep Power: 5 |
I named surface in Ansys modeler as Inlet.
When i imported in to Fluent it is showing as multiple input bodies. Kindly help. |
April 8, 2021, 21:13 |
Alexander
Rep Power: 34 |
one inlet face for each solid zone which you have
by the way, most likely you don't want contacts in your simulation. in design modeler put all solids into one part, in mesher delete all contacts
best regards ****************************** press LIKE if this message was helpful |
April 8, 2021, 22:42 |
#3 | |
Ravikumar Madineni
Rep Power: 5 |
But Its mean we should not divide the inlet or outlet components to multiple bodies. |
April 9, 2021, 09:17 |
Lucky
Rep Power: 65 |
Each zone is a distinct continuum and allowed to have its own physics. For example, one body could be a solid, one a fluid, one empty, a different solid, a diffferent fluid, etc. Each zone can have vastly different physics configurations and the types of boundary conditions that you give to boundary surfaces for these zones can be wildly different and even unique.
Each boundary surface logically therefore is paired only with only one cell zone, unless it is an interface between two zones. If you choose to build your case using multiple bodies even though you intend to have the same physics declared in all of them, then you will end up with disjoint surfaces and cell zones and have additional interfaces. It's not wrong, it's just more number of parts you have to deal with. Just a bookkeeping problem. |
Display Modes | |
[OLAFLOW] The OLAFLOW Thread | Phicau | OpenFOAM Community Contributions | 457 | March 27, 2024 00:59 |
looking for a smart interface matlab fluent | chary | FLUENT | 24 | June 18, 2021 09:07 |
2D Hypersonic Inlet in FLUENT - Convergence Issues | Fraisdegout | FLUENT | 6 | December 15, 2016 02:07 |
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 09:28 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
