Sør-Trøndelag
Rep Power: 4 ![]() |
I am using workbench for a parametric study and I completed all the study. If I want to update the solution, for example by adding a line/plane in my domain or for example by adding surface integral as parameter, it requires again to solve again the problem for all the design points. Is there some settings that allows to upload all the design points without solving again all the problems? Regards. |
Alexander
Rep Power: 31 ![]() ![]() |
if you add parameters to parameter study, you should recalculated, isn't it essential?
if you want to plot something from simulated data, you can extract information you need from data files (which have to be save in advance)
best regards ****************************** press LIKE if this message was helpful |
Sør-Trøndelag
Ok I try to be more clear:
I open solution of dp0 and I create a new line/plane in my domain without creating new parameters. I save the change and I select dp1. Now it appears that I have to refresh the setup and update the solution again. I would like that adding a simple line in the domain do not imply to re-run all the dp in the study. |
Alexander
open dp0, make line in dp0, but don't save changes
make same for other cases you can create line via journal file, probably you can go though all design points using journal file
Display Modes | |
Ho to justify that the problem is stiff in numerical study | ALBATTROSS | Main CFD Forum | 0 | July 11, 2019 17:08 |
FloEFD parametric study | miao | FloEFD, FloWorks & FloTHERM | 5 | April 18, 2017 07:00 |
CFX parametric study | mean5990 | CFX | 0 | January 20, 2017 16:53 |
Workbench in batch mode with parametric study (design point) | Veronique Pe | ANSYS | 0 | June 1, 2016 03:56 |
parametric study in flow simulation | topaz | FloEFD, FloWorks & FloTHERM | 1 | July 13, 2015 08:50 |
