[Sponsors] | |||||
Oliver Wijaya
Rep Power: 6 ![]() |
Hi, I am doing a research in natural convection of lithium ion batteries (I simplified the model as a cylinder in a case) (picture 1). I already did the meshing in ICEM with good skewness and good orthogonal quality. I have some trouble when simulating my model in Fluent.
1. My residual value only shows the residual value of the energy, is that a problem ? (picture 2) 2. After I simulate the model, it appears the temperature contour is a bit strange, the heat flux didnt spread equally in the cylinder. (picture 2) Does anyone ever had experienced in simulating something like these ? Thanks ! |
Alexander
Rep Power: 35 ![]() ![]() |
how your domain looks like?
what kind of boundary condition did you apply
best regards ****************************** press LIKE if this message was helpful |
#3 | |
Oliver Wijaya
My domain looks like in the picture 3. It is only a simple box. About the boundary condition, i applied wall BC for the case (domain) and heat flux wall for the cylinder (battery cells) |
Alexander
inside the box you should have fluid isn't it?
I wonder, why do you have such a low temperatures on the top (circle part) of cells. the difference for central cells is like 3000K on side and 300K on top cells in the center should have higher temperate comparing to cells located close box walls. this is observed plot fluid velocity contours
Lorenzo Galieti
Rep Power: 13 ![]() |
Seems to me a non converged simulation. How are you judging convergence? Just the energy residual?
#6 | |
Oliver Wijaya
Oliver Wijaya
Hi Logal, yes the first simulation I forgot to turn on the gravity so the continuity and the velocity residuals doesnt show. Now it already showed but it only converged to 1e10-4. and still my problem havent solved yet
Alexander
do you have space for fluid between cells and top\bottom walls of the box?
show xz view
#9 |
Oliver Wijaya
yes, the cylinder didnt intersect with the walls
#10 |
Alexander
check material properties of cells, are you using orthotropic heat transfer coef?
and cooling effect is too huge, from my point of view
#11 |
Oliver Wijaya
i am assuming the battery cell as a wall with constant heat flux, and for this simulation i am doing natural convection with 0 pressure inlet and 0 pressure outlet
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| How to implement time-varying boundary conditions in an enclosed cylinder | Alejandro-FA | OpenFOAM Pre-Processing | 0 | May 14, 2020 07:29 |
| Volumetric Heat generation in cylinder with natural convection conjugate heat transfe | sandymech | OpenFOAM Running, Solving & CFD | 0 | August 9, 2017 19:36 |
| Thermophysical properties for natural convection | Ciefdi | OpenFOAM Running, Solving & CFD | 0 | November 7, 2013 12:44 |
| natural convection inside a cylinder | afnene | FLUENT | 2 | December 10, 2010 12:04 |
| Coupled vs Seg - Natural vs. Forced Convection | Alex | Siemens | 5 | December 12, 2007 05:58 |
