[Sponsors] | |||||
Is there such a thing as a defined velocity for the outlet? |
Rep Power: 0 ![]() |
is it possible to set a defined velocity at the outlet? I have a multiphase simulation with a fluid inlet with a defined mass flow and a pressure based inlet of air. The air gets drawn by the fluid "out of" the inlet. So the exact pressure is unkwon. Is it right too just modell it that way, then? Thanks Last edited by Maeki; April 21, 2021 at 17:54. Reason: added attachment |
Lucky
Rep Power: 68 ![]() ![]() ![]() |
If you actually know the velocity at the outlet, yes you can model it that way. In Fluent you use a velocity inlet. It's called a velocity inlet but it is a fixed velocity constraint.
Lorenzo Galieti
Rep Power: 13 ![]() |
You can assign mass flow outlet boundary condition
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Import .csv - velocity profile - error | eSKa | CFX | 9 | April 3, 2021 14:38 |
| kindly help me .. i have and error at line number 147.. | m zubair | Fluent UDF and Scheme Programming | 0 | February 10, 2019 12:25 |
| UDF comilation error. urgent help please | m zubair | Fluent UDF and Scheme Programming | 4 | February 10, 2019 12:19 |
| serial udf to parallel udf | radioss | Fluent UDF and Scheme Programming | 10 | January 19, 2019 09:56 |
| User-defined Outlet Boundary Condition in CFX | modest_may | CFX | 5 | November 27, 2017 23:08 |
